Timing issue
Old Aug 18, 2015 | 09:52 AM
insadj05's Avatar
Timing issue
85 Toyota Pickup 22R engine. New carb, (Weber) fuel filter, fuel pump.
Starts and idles but when raising rpm will back fire. Also cannot get the timing to 0 degrees. it is about 3/8" to 1/2" the the right of 0 and the dizzy is adjusted as far as it will go in the adjusting slot!!!!
Thanks to all for your help.
Old Aug 23, 2015 | 09:11 PM
yoterr's Avatar
So when you rotate the crank around you can't line the mark on the pully to the 0 mark? And did you do anything new besides changing carb?
bigjstang
Jun 2, 2025 03:56 PM
Regency
20
Jan 3, 2020 07:43 PM
coryc85
Sep 9, 2015 06:24 AM
msane99
Jul 11, 2015 08:08 PM
colinmil
Jul 6, 2015 04:03 PM
