steering wheel off center; centered by rotating tires
All,
This is a weird one for me.
My steering wheel was off center. No big deal. The alignment guys always hook up all four wheel readers even though you can't do anything to the rear ones for alignment adjustment. Almost all rear solid axles are a bit off so when they use that as the mark the front wheels follow. Then the steering wheel is off center. Steering is still lined up. So no big deal. Sorry for the tangent.
Anyway, after a recent tire rotation, my steering wheel is now straight. So how can an off-center steering wheel be centered by rotating tires front to back?
I'm dying to know the geometry that causes this.
Thanks.
Thanks.
Are they doing a crisscross back to front and fronts straight back or are they doing a straight back to front, front to back. The steel belts adapt to primary direction of rotation, thus a tire on the right rear when moved to the front left changes the direction of rotation and with some tire brands belt memory or tire wear will change the handling of the vehicle. Sometimes it is not the tire manufacturer as much as it is just one tire developed different memory.
If it runs straight right now and they have been doing the crisscross rotation then I suggest the next time they rotate them just have them do the back to front, front to back method and see if it still runs straight. If not then flip flop the fronts and see if that fixes it. IMO this is a more common issue then it should be in the ideal world.
Tires are evenly worn. They are pretty new as this is the first rotation. Double checked with a tread gauge this morning just to actually quantify it. All good.
I'm thinking belt damage to a tire would be pretty obvious. Am I wrong? What should I look for here?
The tire rotation is always just front to back, no criss-cross. Though this time I did not actually watch the tires move.
Thanks for thoughts. This is a real stumper for me.
It is not that there is damage to the belts, it is just that they can develop memory. For example you park a vechicle for a few weeks the tire will develop a flat spot and cause a tire to feel out of balance, when if rebalanced they are still in balance per the computer. Some vehicles prefer a crisscross style rotation, but if not done regularly then the straight back to front vise versa is usually best because the tire(s) have had sufficient time to develop their memory. I recommend playing with the rotation style and find what works best with your vehicle and tires. Note that when you get new tires the rotation style may change.
FS[PacNorWest]: Factory Alloy Wheels - Bay area
94whiterunner
9
Sep 22, 2015 07:28 PM
