4.3l swap
4.3l swap
Ok the 22r in my 1983 Toyota blow so I am wanting to be a 4.3l swap
What I need to know
I am going to be putting a carb on the 4.3 so no problem there wiring is easy
As far as power steering will I have to have hoses made
Can I used the radiator out of the donor truck (don't have one yet so a truck/blazer)
What would be the best trans to use I want to keep overdrive and convert to a manual so 700r4 would be the best right
What year trans do I need to get that is not electronically shifted
Using the AA motor mounts and tcase adapter I can mount a 700r4 to my Toyota tcase
What I need to know
Best bet would be so start reading in the 4.3 threads in here:
https://www.yotatech.com/forums/f163/
then post up questions there. More traffic from the vortec guys there.
Good luck.
Good luck.
