93 22re takes 5+ cranks to start
Old Jun 22, 2015 | 06:01 AM
slider417's Avatar
Guys,
Not sure if this s 'warm start ' issue or not..
Put on a new cap, rotor, plugs and wires a week ago.. truck started up fine and ran like new. I was having a problem with a bad misfire and this fixed the issue
Now whenever I go to start , the truck takes more than 5 cranks to start and idle. It will start but will not idle and the motor will eventually die..
Once it finally catches and idles, the truck runs perfectly fine..
Is this the warm idle issue or something else ??
Old Jun 22, 2015 | 10:18 AM
Terrys87's Avatar
All hoses on correct and sealed up? The Intake system gets dirty inside due to carbon build up from the EGR. Might want to try and clean it up. Sensors usually need a good cleaning as well. https://www.yotatech.com/forums/f198...l#post52044719 Shows how bad the sensor and EGR can be.
Ichneumon
Sep 27, 2015 04:21 PM
Sandman
Jul 23, 2015 08:15 PM
ian1386
Jul 1, 2015 11:23 AM
jmc88runner
Jun 18, 2015 03:39 PM
