Where to find Power Steering for 85 turbodiesel 2L-T?
I have a USA 1985 toyota with the 2L-T. My power steering pump is making a loud scratching sound, and leaks. Does anyone know where i can find a new or used P/S Pump in good condition.
I am looking at one on ebay from australia, but it says its for the Hilux Surf which i believe means its the 1986 which is different from an american made 2L-T P/U.
The description on ebay now follows:
To suit: Hilux SURF models fitted with the 2LT and 2LTE 2.4 litre Turbo diesel engine.
The pumps on this model have a bad habit of leaking or wearing out the housing around the long mounting bolt.
This pump has a splined shaft to mount the pulley. Please check to make sure yours is the splined type. Earlier models have a keyway type pulley fitting. Just remove the nut on front of the pulley and you can easily see what type it is.
so i am currently checking my P/S pump to take off the pulley wheel and see if it is splined or keyway, to see if it fits.
Anyone got any suggestions? Anyone know any other place i can find the P/S Pump?
Maybe post up some pictures .
I have never seen one of those engines.
For what it is worth Napa Has a listing for reman pumps for that engine.
The difference between the two pumps is how the out put line attaches.
Jun 1, 2021 01:51 PM
Johntom240
7
Jul 13, 2015 12:18 AM
jon.r
Jul 11, 2015 03:34 PM
