95 Toyota 4Runner won't start
I just replaced my injectors because a mechanic told me they were bleeding off the pressure into the cylinders. While I was at it I did the spark plugs and wires. I got it to start and drive around the block once but it was very shaky and had almost no power. Now it won't start at all and after I turn it over I can hear what sounds like air pressure bleading off. What do I do?
Might be nice to know just what engine??
Injectors harness not on correct
Wires not on correct
coil wire not seated in the coil fully .
Then it might be unrelated to the work you just did.
FS[MidWest]: 1995 4Runner 5vz 4x4
vasinvictor
Jan 20, 2016 12:39 PM
