2nd gen 4Runner body swap
Old Apr 25, 2015 | 12:03 PM
Cpetersen21's Avatar
Hey has anyone swapped body's off 2nd gen 4runners ? I have a rust free body an would like to put it on running 4Runner. So my question is what is all involed in take the body off ?
Old Apr 26, 2015 | 05:55 AM
fierohink's Avatar
I haven't pulled the body on a runner but I did pull the cab and bed on my pick-up when u redid the frame.
A Runner cab is heavy so consider using a lift or bobcat or something to pick it up.
Remove the interior, seats, doors etc to lighten the load. Disconnect everything that goes from the body to the motor or frame. Electrical plugs thru the firewall, fuel lines, throttle cables, brake lines, etc. there is an electrical plug under the front passenger seat too (that may be truck specific) that runs the tail lights and fuel pump. Disconnect your body mounts and lift.
Like I said, I did a standard cab pick-up with 3 buddies and had no problem. A Runner can weighs probably 2-3x more. Plus you have to lift it high enough to clear the motor unless you pull that first. So figure lifting chest high.
Old Apr 26, 2015 | 06:35 AM
Terrys87's Avatar
I have done a first gen runner and second would not be much different. Here are some steps https://www.yotatech.com/forums/f199...l#post51693382
Old May 21, 2015 | 12:30 PM
central4runner's Avatar
I just got sone doing this to a 2nd gen. It was pretty easy actually, I bought a extremely clean crashed up 4cyl with a fubared frame then found a v6 one with good frame and bad engine. the worse part of it was redoing the engine mounts to keep the 4cyl. As fierohink said just disconnect everything from body to frame and lift. I used my walnut tree to lift mine like this:
Old May 21, 2015 | 02:13 PM
RJR's Avatar
RJR
That's an awesome walnut tree for that purpose. How long did it take from when you planted it to get to where you could use it as a lift point?
Old May 21, 2015 | 02:17 PM
Haha i have been told it could 70-80 years old i have no idea, but yeah it worked perfect for it. If you look in the second pic you'll notice that it is 2 different trees grafted together, black and english walnut
AustinTaco
Aug 22, 2022 10:45 AM
marcusSRG
Jun 27, 2015 07:13 AM
Niameyrider
Jun 25, 2015 05:50 AM
infinityisfive
Jun 16, 2015 06:51 PM
HALMAN
Jun 24, 2002 06:01 AM
