22r offenhauser intake thermostat ????
heres my dum question for the day what flipping thermostat fits the offenhauser c-series intake its an 82 22r. I know its a thermostat type seal but cant seem to find a thermostat that fits any helps would be great thanks
Strange question, should just be a thermostat for the 22r. Is a "C" series the dual plane or single? Not that it should make a difference.
The only reason I can think of is that you ended up with a "late" 22r water neck ('83 up) and it isn't sealing to the manifold? The offy's require an early water neck, which your '82 should have, unless someone swapped in a post '83 engine at some point.
I had a dual plane offy/weber 32/36 setup on my 81 previously and everything bolted right up and used the stock thermostat.
If you have the late style water neck here's a solution for you.
http://www.lceperformance.com/20R-22...-p/1032086.htm
Or give more info specific to the problem and we'll see what we can figure out.
Blamalam
Mar 12, 2022 07:34 AM
