Sponsored by: CARiD
94 Toyota pickup 2wd front hub remove help
Old Apr 11, 2015 | 10:34 AM
alva22re's Avatar
I have a 94 pickup 2wd and i want to know how to remove the hub from the rotor. The hub has five bolts that hold the rotor with, is that the only bolts i need to remove thanks in advance.
Attached Thumbnails 94 Toyota pickup 2wd front hub remove help-20150411_110034.jpg   94 Toyota pickup 2wd front hub remove help-20150411_110046.jpg
Old Apr 11, 2015 | 11:23 AM
wyoming9's Avatar
Red face
You need to pull the caliper off and out of the way.
Then you need to remove the outer wheel bearing
Then you can pull the hub off being careful not to ruin the wheel seal.
Old Apr 11, 2015 | 11:38 AM
alva22re's Avatar
ok thanks does the outer wheel bearing needs to be press-fit
Old Apr 11, 2015 | 05:10 PM
Robert m's Avatar
No. Once you remove the cotter pin and big nut in the center, the whole hub and rotor will just slide off. When its about half way off the spindle, push it back on and the outer bearing will be sitting on the threads where the big nut goes.
6th Gear
19
Dec 10, 2019 07:31 AM
GorgeRunner
Jun 27, 2015 07:01 AM
dirtrider0129
10
Jun 24, 2015 12:24 PM
paxanders
Jun 21, 2015 06:29 AM
bobbybouche
Jun 18, 2015 10:22 AM
