Hello all, I'm in the process of restoring a 86 pickup and have had some problems with correcting the factory trailer wiring harness. The PO made a huge mess of it, cutting it off where it originally connected and splicing it in to the wires in the loom using vampire taps. Basically the end of the factory connection and the end of the trailer wiring harness don't exactly match up. If anyone could provide any information on how they're supposed to connect, I would be extremely grateful!
Here is where I assume the factory wiring harness is hooked into the driver's side tail light. The wires coming out of the plug and going down to the right in the picture are where I assume the wiring harness should connect.
In this picture the wires on the left are the ones coming from the tail light, and the ones on the right are the ones going to the factory trailer harness. I assume the colors simply match up, but what I'm not sure about is where the light blue wire should connect (which connects to the reverse light at the tail light) and where the white ground wire should connect.
Thanks in advance for the help!
The converter box with the 4 pin plug is still there. These wires are before the converter box.
Ok, thanks, that helps. But do you know if these wires coming off the drivers tail light plug are supposed to go to the trailer harness? They were simply hanging down under the truck unattached to anything so I assumed that they must. All the needed connections are there, with a separate green wiring coming from the passenger turn signal. I'm just not sure where the light blue reverse wire should hook up to the trailer harness.
I am not near my truck now and don't recognize the blue wire right off. Can you just connect it back to the way the factory had it? I use these kits and no issues.
Copied...
I got my tail light conversion kit, still need to get it installed and need a drop hitch. I do a lot of pulling. Its PN# 43315. I get mine at Oriellys.
