Two possibly dumb questions about a W56 swap
My L52 is noisy and leaky, so I'm thinking of upgrading to a W56 sooner than later. It's longer and needs driveshaft mods and it has to be a forward-shift otherwise bla bla bla... but, about the crossmember:
Instead of moving the whole thing back, can't I fab up somekinda plate that moves just the rubber trans mount further back on the stock crossmember in its stock location? Or keep the rubber in the same place but bolt it further forward on the new transfer case? Seems a lot easier. I eyeballed front driveshaft clearance and at least with no lift (I don't and I won't) it seems it *should* work...
On a related note, are there any alternatives to a crossmember? I looked at Budbuilt, but paying 200 for something I have to jury-rig on with U-bolts does not sound good to me.
About the transfer case: will my original bolt up to a W56? If so, is there any other reason to use the one that comes with a W56? I hear this difference about "noisy" vs. "quiet" gears but mine doesn't seem noisy at all.
This may be a solution http://www.lowrangeoffroad.com/yotam...r-plate.htmbut does not have a skid plate. Easy enough to make one.
Might be a good time to consider dual cases!!!!!
EDIT: looking carefully, I don't see a front driveshaft at all in your setup.
The reason for asking this question is so I can upgrade to a W56 now before my L52 goes kaput, without having to get deeper into other modifications and upgrades. The stock crossmember, rock anchor that it is, is itself something to upgrade regardless of t-case fitment.
You have one that I don't need? Or did you mean to type "that I don't need"? Can I buy yours?
Quote:
Originally Posted by 1st Gen Crawler View Post
I think this is what you are talking about, i did that. it works ok. 2 years ago it was just supposed to hold me over till i got around to installing my dual cases.
I guess that confirms my eyeballs, that the front driveshaft doesn't have clearance issues? That's welded onto the stock x-member, yeah?
Note that i probably could not install the front shaft even if i wanted to due to clearance. There is a way to use angle iron and use that to move the entire cross member back.
Just to be clear: Has anyone installed a W56 in a first-gen, kept the stock crossmember, and bolted up a stock (well, lengthened) front driveshaft without clearance issues?
Moroza, You are correct. Mine does NOT fit. Perhaps you could use a spacer where the DL meets the Tcase? I do believe the TG dual case cross member will work with a single case setup. I could be mistaken though.
Roger of 4Crawler off road makes the only d/s I would use
http://www.4crawler.com/4x4/ForSale/...ftSpacer.shtml
I know I could and I would think you can as well.
