91 Toyota Cylinder stuttering
Does it only happen when changing gears or can you reproduce it at low rpms staying in gear?
Have you checked grounds?
https://www.yotatech.com/forums/f116...-guide-194413/
I would say try these things first:
• Test AFM and check for free play in the flapper, if there is any notch feeling or sludgy resistance it needs to be cleaned or replaced.
• Try unplugging vac line from the fuel pressure regulator and cap the vac line so it doesn't cause a vacuum leak into the manifold. I am thinking perhaps your fuel pressure regulator is getting stuck.
• Last time injectors were serviced?
There are good things that come of this though: the obvious one is getting things working properly, and secondarily learning what made it work and taking that nugget with you forever. Kind of a win-win. You have to love these vehicles for their approachability and simplicity when it comes to that stuff.
jerusry
Oct 19, 2015 05:28 PM
