wing window
Old Mar 10, 2004 | 02:25 PM
chasmc2's Avatar
wing window
I need help with inserting the damn thing Its not in my book and I cant find it on the search. someone please help
90 4runner
Old Mar 10, 2004 | 03:11 PM
86toyota's Avatar
Are you replacing just the glass or the whole frame, track glass assy?
Old Mar 10, 2004 | 10:17 PM
chasmc2's Avatar
Question
the glass with the bottom closing piece attached to it. how does it come out of the door. do you have to take the panel of? or what.
Old Mar 10, 2004 | 10:20 PM
Shane's Avatar
On the older trucks there's a screw under the door seal on the front edge of the door that holds the frame in, mabye check there? There will also be a few bolts under the interior panel that you have to remove.
Old Mar 11, 2004 | 05:17 AM
86toyota's Avatar
To make it alot easier you should remove or lift up the door panel, wind down window and remove the 2 bolts holding the main window on the track,let it sit in bottom of door, remove the one 10mm bolt for the front window track(that tract is part of the wing window), Like shane said, look for phillips screws on the door post, and then it should come straight up, you'll have to kinda twist it out at weird angles....I don't think you can remove it with main window still attached. Hope that helps.
Old Mar 11, 2004 | 06:21 AM
Shane's Avatar
Yep, main window has to be removed from the track in order to get it out. It can be left in the door, but it may be easier to just pull it out.
Old Mar 11, 2004 | 12:43 PM
chasmc2's Avatar
cool ill give it a try they want 50$ at the dealer
RDubya
Feb 10, 2017 04:46 PM
PNW94Runner
Sep 29, 2015 02:55 PM
tazman1972
11
Sep 28, 2015 10:32 PM
punks_is_4x4
Sep 19, 2015 05:52 AM
mat
Sep 17, 2015 11:18 PM
