1990 toyota pickup running great then go out to work and no start
Hey everyone im mike...northern California....good ole boy
I bought this 90 toyota pickup v6 motor. It was running real real good for couple days...go out to work yesterday....nothing. im mean it cranks good....but nothing not even a burp. Checked fuel filter...clogged as f@@@ replaced. (Can this cause pump to go bad?) Still nothing. Pulled fuel rail fitting seems to be pumping gas...but of course theres no way to measure pressure this way w no guage....pulled a plug....very dry not wet at all. I haven't verified spark tilll I have a assistant here....now....theres no choke obviously....but is there some other cold weather provision im missing to check here?? Thanks ill keep updating. 3.0 efi motor
Check to see it the coil wires are tight and if it has power when the key is in run position. Check for breaks in the line.
Check to see if the power wires to and from the distributor are getting good connection. Check for breaks in the line.
It's a good time to pull out all your fuses (one at a time) and test them. When I have to look at my fuses I test them all and if anything looks corroded of funny I just replace it even if it still works. Some of those are probably 20+ years old.
I did the diagnostic jump wire....but whoever had this truck lost its cover so opening of ports h ella corroded w dirt n stuff. I cleaned best I could ran small wire key off...then on....both times nothing (couldn't hear anything)
I cracked fuel rail motor crank few times....gas spurts. ...
however...
looks like someone did a clutch pedal bracket fix....looks like fuse box knocked around missing bolts...it just flops up there....
however...
however...
however...
Also, if the fuse box checks out, i'd grab an inline spark tester, takes one person to do, will tell you if you are getting spark.
If you have more problems with corrosion a product that helps corroded or bad connections is called DeoxIT.
There are a few different formula's and it's expensive, because it works.
Works best on smaller contact area's like fuses, connectors, and switches.
It's not meant for battery cables and larger stuff like that.
6th Gear
19
Dec 10, 2019 07:31 AM
Crazy_Guy97
12
Jun 24, 2015 04:02 PM
dirtrider0129
10
Jun 24, 2015 12:24 PM
