'94 Toyota V6 pickup dies at an idle
Old Oct 9, 2014 | 01:14 PM
andrewfreeman15's Avatar
I have a 1994 Toyota pickup v6 that dies at an idle but when I drive it runs fine, as soon as I come to a stop it sputters and dies within seconds if I don't give it gas. I would like to clarify there is NO vacuum leak. I have no idea what else would cause it to die only at an idle. Any suggestions would be much appreciated.
Last edited by rworegon; Oct 10, 2014 at 07:40 AM. Reason: Copied in first post w/ more from thread to be deleted.
Old Oct 9, 2014 | 01:21 PM
fdp101452's Avatar
Have you adjusted the idle? Whats the timing set at?
Old Oct 9, 2014 | 01:24 PM
Well I'm not really sure how to adjust the idle!
Old Oct 9, 2014 | 04:22 PM
oldblue's Avatar
maybe a vacuum leak. can you hear hissing from the engine at idle? a smoke machine is best for finding leaks, but i doubt you have one of those laying around. if i don't have my smoke machine, i like using brake cleaner to find leaks. just start spraying it around the intake and all vacuum hoses and the intake hose and see if the idle raises. some will whine and say this is a bad idea, but as long as you do it on a cool engine and keep it away from the distibutor cap you should be fine. i ain't burnt one down yet...
Old Oct 9, 2014 | 08:48 PM
nv4runner's Avatar
You can also use an unlit propane torch to check for vacuum leaks. Make sure you check under the air intake hose at the throttle body. Easy spot to miss, but likely to crack or split.
Old Oct 10, 2014 | 07:12 AM
scope103's Avatar
Check Ignition timing.
Check idle speed. http://personal.utulsa.edu/~nathan-b...nce/2maint.pdf
JNapolitano
Nov 14, 2019 07:46 PM
jasonty
41
Dec 23, 2018 01:00 PM
montanatruck
Feb 26, 2017 07:07 AM
Alex Bessinger
Aug 31, 2015 09:17 AM
corey519
Aug 12, 2015 11:12 AM
