3.4 Vacuum line mystery
Old Aug 3, 2014 | 03:14 PM
mikea71's Avatar
I just completed a head gasket job on my 3.4 engine and I seem to have a mystery vacuum line I cannot find where it goes. There are3 metal vacuum tubes sitting on top of the fuel injection. The thinner tube has a "T" on it and I found one end of it not hooked up to anything. For now I stuck a yellow cap on it. Can someone tell me when this goes??
Also on I side note when I hooked the wire harness to the TPS (throttle position sensor) I noticed a connector not connected to anything. It is so short nothing will reach it. Maybe its not used on my engine but was curious what it was for.
Regards,
Mike
[IMG]Name:  IMG_0361.jpg
Old Aug 3, 2014 | 04:22 PM
rworegon's Avatar
Mine heads to a check valve and then to the controls for the ADD diff/hubs VSV......original from the factory. On a swapped engine, hard to say...you should have a loose tube someplace.
Old Aug 3, 2014 | 04:43 PM
slacker's Avatar
typically that is just a 90* elbow .. I would think someone had a gauge plumbed into that line ..
Old Aug 3, 2014 | 04:46 PM
rworegon's Avatar
Mine straight from the factory 95.5 5vz-fe is a "T", not a 90* with the ADD diff/hubs.
Old Aug 3, 2014 | 04:52 PM
slacker's Avatar
absolutely .. and that looks like a factory " T " .. and possible explanation of it being blocked off , maybe the previous owner went with manual hubs ? IDK? .. I was just offering some more info for the fella ...
edit .. ohh I guess I didn't read enough .. you just did the head gasket ! sorry , I missed that .
so yeah , obviously it had to be hooked up to something
Old Aug 3, 2014 | 04:58 PM
rworegon's Avatar
so yeah , obviously it had to be hooked up to something.
Unless, it's been uncapped and not noticed? I see in another post he's going to leave it capped and see how it goes.
Old Aug 3, 2014 | 06:46 PM
vwrunner's Avatar
My 3.4 had that port originally capped also. I used that port to connect to the cruise control vacuum servo. Mine is vacuum operated, later ones are not.
raptor510
Aug 19, 2015 02:15 PM
Tacoma1313
Aug 17, 2015 05:44 PM
Poppie51
Jul 23, 2015 05:03 PM
jgwerth
Jul 16, 2015 03:23 PM
TokyoD23
Jul 12, 2015 06:01 AM
