Mystery problem
Old Jul 28, 2014 | 08:50 AM
sravbrown's Avatar
Mystery problem
My 85 with a 22re runs great at idle, new fuel pump, tps, afm from known working source. The truck has no power to get down the road. I can't use 4th gear. It does seem to do a little better after it has warmed up, I feel like I may have the valves to tight and they are not opening for fuel. When floored in the appropriate gear the truck falls on its face will decelerate and lean out. I am stumped and I really need to get this fixed
Old Jul 28, 2014 | 08:57 AM
JasonYota's Avatar
Have you adjusted the valves like you suspected?
Did it all of a sudden become a problem? Just buy the truck?
Old Jul 28, 2014 | 09:31 AM
sravbrown's Avatar
I put the motor together from a long block it was running ok and got progressively worse I'm not ruling out the possibility that the valves loosened up, I tend to not put massive torque on bolts since it's a 30 yo motor. It does run better when it's warm but still n
Old Jul 28, 2014 | 09:32 AM
sravbrown's Avatar
I put the motor together from a long block it was running ok and got progressively worse I'm not ruling out the possibility that the valves loosened up, I tend to not put massive torque on bolts since it's a 30 yo motor. It does run better when it's warm but still not right. I did do the initial adjustment but I'm a novice with the valve train.
Old Jul 28, 2014 | 01:49 PM
Terrys87's Avatar
I didnt see you say if you installed a new fuel filter. When they start clogging that can slow them down. Is the catalytic converter clogged as well maybe? I had a damaged converter and removed it and had a great running motor afterwards.
Old Jul 30, 2014 | 09:54 AM
redbayredneck's Avatar
I'm almost positive he's running a fairly new filter, and I don't think he even has a Cat on his truck.
If he was, I'd say its the Catalytic converter... Its acting a lot like my Jeep did when it had a clogged Cat.
Old Jul 31, 2014 | 11:28 AM
gunpilot's Avatar
My truck was doing the same thing. When I accelerated like an old lady, it was fine but would barely have the guts to get to 4th gear. I grabbed a 12MM wrench, loosened my distributor and increased timing by ear. Drove down the road and it got a bit better. Stopped on shoulder and increaded timing a bit more. Drove hard again and it got better. The 3rd adjustment got me where I needed and truck stopped hesitating and bogging down. Tightened distributor and off I went. Never used a light to see where timing is, but truck seems to like it either way.
Old Aug 17, 2014 | 08:11 AM
mikeyd6789's Avatar
Maybe clutch?.... Leaky master cylinder? Might not be getting power to the wheels.
theking11863
Mar 19, 2016 09:36 PM
RaginAsian91
All Other Toyota Swaps
Aug 23, 2015 10:27 AM
Jonny246
Jul 24, 2015 12:37 PM
Yota.Jay
Jul 23, 2015 08:08 PM
Odin
Jul 15, 2015 09:28 PM
