Rough idle in cold start, possible leaking injector???
So the motor I have in my 89 pickup is from a 99 4runner. 3.4l unknown miles. Been noticing a rough idle when started in the morning so today I pull the plugs all look great good coloring not all clean like coolant. Next I psi tested the radiator held strong at 15psi. Next was the cyl leak down test. All cyl tested good little pressure lost not bad though. (Could be leaking past rings valve seal ect. So I went ahead with the comp test all cyl tested above 195psi no more than a 15psi difference.
So I am curious is there a possibility the injectors are not closing completely? Dripping a small amount of fuel over night causing it to run rich? In a matter of min of running it clears right up runs like a top. Any one have any experiences with injectors leaking?
Thanks Clint
Thanks Clint
jennygirl
Nov 17, 2015 11:24 AM
jmc88runner
Jun 18, 2015 03:39 PM
