Will newer TRD wheels fit on my '87 Pickup 4x4
I'm looking at 16" TRD wheels (6 x 5.50 or 6 x 139.7)
http://www.ebay.com/itm/Toyota-FJ-Cruiser-2007-2014-TRD-16-BLACK-Alloy-Rims-Set-OEM-NEW-/131109767685?pt=Motors_Car_Truck_Wheels&hash=item1e86c04a05&vxp=mtr
I'm pretty sure they will work but eBay's "compatibility tool" says that they aren't compatible so I just wanted to double check with you all!
Yes and no. I have a set of txpro wheels I'm currently working on top for my 89. The problem is the hub opening on the wheels is not large enough to clear the manual hubs. So you have to machine the inner lip off the hub on the wheel a little bit to allow them to clear. Then you can't run the center caps as the lip on the hub of the wheel they snap over is now gone so the wheels can fit. That being said you can probably create another way for the center caps to go on.
But no they are not a simple bolt on and go
dirtrider0129
10
Jun 24, 2015 12:24 PM
