truck speakers won't play music!!!
So I just got done rewiring my 1991 toyota trucks speakers and I have a kenwood deck. My driver front and back speaker work, but my passenger front and back won't play music! When I adjust settings like fader I hear the passenger speakers beep, but no music comes out. It's confusing the he'll out of me.
When I wiggle the wires that go into the back of the deck, however, the passenger speakers will play music for like a second and then stop, so I know they work. But i have to wiggle them for like 5 minutes and get lucky for 1 second of music. All of the connections I made with connectors are fine and firm. Maybe it's the harness that plugs into the deck? Help please
heres some easier trouble shooting to start out with.
at the radio with all of the speakers hooked up, strip back the speaker wires in question just enough that you can touch them with a drill battery or a 9volt battery (making sure the speaker wire is still connected to the radio as well). when you touch the battery to the wires, the speaker should "pop" if this happens, then there is most likely not an issue with the wiring, but more so with the head unit.
another way to test is to completely seperate one set of the speaker wires in question from the radio. then using a spare speaker, hook it to the output of the radio. If this allows the speaker to play, then the headunits output is fine.
check to make sure the speaker terminals arent touching metal and grounding out somehow as well.
there is a left and right audio ring on your aux cable (look at the tip of the cable, there will be two or three rings, most likely black, the 3rd would be for video) I have a galxy s4 and had the exact same issue, the audio only worked on the right side of my 4runner. i eliminated the cable and stream everything thru bluetooth now. no worries about bad cable, bad phones etc.
AustinTaco
Jun 21, 2015 09:54 AM
C2damuthafuqinLO
7
Jul 21, 2002 09:27 AM
