Sponsored by: CARiD
backspacing-fender flare fit?
Old Mar 8, 2014 | 09:04 PM
Waylayer's Avatar
Want to push out tires without using 2-3" wheel spacers. Have 3" fender flares and no longer running 33x12.5's. From the searches and getting back spaced on back spacing I think I would need around 6" back spacing, but what I have now and other wheels are about 4". Would it better to go with a smaller spacer and little wider tire then to compensate with back spacing. not sure of any where that sells cheaper steel wheels with lots of back spacing.
Old Mar 8, 2014 | 09:11 PM
scuba's Avatar
You need to decrease the back spacing if you want to push the tires out.
If you have 4" BS try 2.5"-3" back spacing.
Old Mar 10, 2014 | 05:25 AM
Waylayer's Avatar
Less space between back of wheel and lug holes with less back spacing meaning tire mounting surface is pushed out from hub.
Old Mar 10, 2014 | 07:03 AM
93Xtra-Cab's Avatar
Why don't you just take the fender flares off?
Old Mar 10, 2014 | 08:04 AM
Waylayer's Avatar
Was thinking about doing that, they are screwed in so id have to patch holes somehow Planning on running bigger/wider tires at some point but need to swap out gears (4.56 to 5.29) and not at that point yet. I got the flares for a good deal by trading my old clutch and trans, so I figured id run em. Had 12.5 wide tires then, running a more narrow tire now.
Old Mar 11, 2014 | 09:27 PM
Waylayer's Avatar
This what im working with now. maybe 1" spacers would do it.
Zach_trun
Jan 22, 2020 04:42 PM
94toyy
12
Sep 14, 2015 06:18 AM
fabing455
Sep 7, 2015 08:08 AM
justdifferentials
Sep 5, 2015 06:52 PM
