birfs assembly
birfs assembly
Ok so I'm losing my ˟˟˟˟˟ here... Finally completing my SFA rebuild and after partially assembling my birfs (cage, sphere, balls etc.) I'm unable to get the axle shafts together - I can't seem to budge it past the clip.
I've tried the following:
- pounding together (Ya I don't believe you when you say this works)
- two small screw drivers
- hose clamp (one I've tried is a bit too big to sit flush in the cage)
- Zip tie - always slips off
So anyone got any new tricks that have worked?! Or am I just ˟˟˟˟in retarded?
Thanks!
Thanks!
Thanks!
Thanks!
Well I'm working without a vice... and solo... will try and find a different hose clamp and get that to work... think Yota could have come up with a better way here!! But, I suppose it works for most.
solved
Solution was to get extra wide zip ties and modify the pinch thing by filing it so it would sit flush. Success!
punks_is_4x4
Feb 26, 2016 04:29 PM
LCE_Performance
Oct 1, 2015 01:03 PM
AustinTaco
Sep 18, 2015 08:58 PM
