water pump change, wojt start
Old Mar 2, 2014 | 05:52 PM
chickenhammer's Avatar
Had a bad water pump on my 1996 Tacoma with 3.4 and put everything together and it won't fire up, it's got fuel, spark, obviously battery, I've checked fuses and everything and still can't get it to start
Old Mar 2, 2014 | 06:24 PM
sr5lifestyle's Avatar
While doing the water pump change did the timing marks on the crank and the 2 cam gears stay the same? Did you double check it before closing everything up?
Old Mar 2, 2014 | 07:40 PM
When I opened it up (facing the motor) the right cam gear was lined up straight 12o clock and the left one was at 10 o clock, I straightened the left cam to match the right cam at 12 o clock and then put the belt on and lined up all the marks
Team420
Jan 12, 2021 04:57 PM
voiddweller
19
May 2, 2016 09:10 PM
Ichneumon
Sep 27, 2015 04:21 PM
B. Graves
Jul 3, 2015 04:10 AM
Mutinebullfrog
Jun 18, 2015 01:36 PM
