3.4 swapped 90 4runner falling on its face
I have been driving my swapped 90 for two years now with almost no issues at all but lately its started to act strangely. It will fire up and idle perfectly but as soon as you give it any throttle it bogs badly. so far in effort to find the issue I have replaced the cat, plugs , wires, tps,fuel pump, replaced the C.o.r and eventually bypassed it all together because I was not getting a prime cycle from the ignition and nothing has helped even the slightest bit. while checking my live stream data the ect looks to be reading correctly but randomly throws a speed sensor code ( my sp1 wire was tied into the combo meter during the swap). I currently have both o2 sensors disconnected and that made no difference.
I am sure I have over looked something simple but I am at a lose .. throw some ideas at me
thanks
thanks
I have cleaned both the throttle body and the mass air thoroughly. but im not sure what you mean when you ask if its running in open loop or closed loop.
if you mean has it thrown code after all these attempts,.. no I have not been able to get the truck to go more than 50 kph for some time now
new fuel filter as well .. it will rev up to 5k but sounds a bit off when you do. I just took the truck for a run with the o2s unplugged and got a p0125 and p0135 as you would expect with unplugged o2's
so I ran injector cleaner and it made no difference at all. So I started going through the live data again and noticed that it is retarding the timing back to -40* I was under the impression the 3.4 would only retard the timing to -12*. anyone run into this in the past ..
I
I
ok I found a vac line thats obviously been off for a long time under the intake. while im in there does anyone have a good method for testing the fpr with out the truck running?
Have you checked your intake boot for large rips or splits? I remember reading someone else had this issue and there was a gaping hole in the intake boot causing unmetered air into the motor. Worth a shot
After checking the timing marks and noticing that the cam marking and crank markings were not quite right I removed the crank pulley and found that the crank timing gear has worn on the woodruff key and is now moving freely back and forth one whole tooth (1/4") but will not freely slide off of the crank shaft. I've never seen anything like it before but I suspect this is the root of my problem.
FS[SouthEast]: Mercury Villager Fan & DCC Fan Controller
coryc85
Sep 9, 2015 06:24 AM
