cold start injector time switch wiring question
I am trying to find out the proper wiring for the injector time switch. I am new at reading wiring schematics so bear with me. There are two wires that come from the switch a green one that goes to the ECM and a black one. On the schematic it appears that the black wire goes back into the green wire. My question is: is the black a ground or does it mean that it is a closed circuit? Reason being that I found the black one just hanging loose under my EFI intake and it looked as if it was twisted and jammed in somewhere. I just replaced the switch and don't want to burn it out because of bad wiring job???
Totally makes sense, thank you so much for your help. Maybe now she will start and run right again. shoooo...this wiring thing is wearing me out. I think I will change her name from Tuesday to Frankenyota...lol. Tuesday has a manual transmission too, glad I didn't touch it might have had a wire fire...not good. The schematic I have did not specify that the black wire goes to the ignition only back to the STJ wire. Now I just have to track it back to the ignition and injector to put it back where it belongs
Tracking it back
I have to track it down to reconnect it, the wire going to ignition was just hanging under the EFI intake. When I found it I just stared at it for a few scared of it...lol. I have spent some time fixing some seriously ghetto wiring issues since purchasing the truck. I can honestly say it would have been easier to build it myself. Good education though, I will build the next one with confidence
jmc88runner
Jun 18, 2015 03:39 PM
Mystery solved, black STA wire not connected to starter. That should solve the injector and time switch issue
