1986 Toyota P/U tach, oil pressure and temp gauge quit working??
What would cause my tach, oil pressure and temp gauge to all stop working simultaneously? Any help would be appreciated
You have other issues as well? Her is how I fixed mine. Several things on that circuit. Look at the plug below and see if it is knicked and shorting on the tranny. Haynes Manual page 12-11 shows what all is on this circuit.
Copied...
I blew the Engine fuse again. Doing some research. I havent found a 100% fix so am trying to come up with one. One link says to check Fuel pump harness. Also found that O2 sensor could case problem.
FIXED!!! Mine was the Reverse Lights on the Tranny. It has a protective sleeve and depending on how the sleeve slides, it can cover the wires where they rub against the tranny leaving them exposed. Below is other fixes for this problem.
Copied...
the1998sr5
Oct 19, 2016 12:48 PM
