93-98 T100s All T100 trucks
Best way to lift the rear of a truck under $300
Old Jan 11, 2014 | 07:35 AM
jaretstuff's Avatar
I want to lift my Toyota T100'about 2inches in the rear.
Which way is the better way:
Longer shackles
A rear block
Different springs
An AAl system
Regardless of money which on is the best most professionally way to lift it.
Old Jan 11, 2014 | 08:51 AM
JasonYota's Avatar
Chevy 63in springs FTW
Old Jan 11, 2014 | 09:02 AM
jaretstuff's Avatar
what all is required for that mod. do i need custom mounts or anything weird for it. what does the 63 stand for is it the length. where is a good place to purchase it.
Old Jan 11, 2014 | 09:04 AM
JasonYota's Avatar
Do a search on pirate on it, there's enough info to read for days. You might have to search specific T100 swaps to find where to place the new hangers though
Old Jan 11, 2014 | 09:08 AM
JasonYota's Avatar
I should have asked first but what are your plans for your truck? Why do you want to lift it a little?
Old Jan 11, 2014 | 09:27 AM
jaretstuff's Avatar
i am running 33s on my t100 without a lift and ii jus want to lift it enought to clear the tires when the suspension is compressed but still keep cog low for sand dune running.
Old Jan 11, 2014 | 09:38 AM
JasonYota's Avatar
Chevy 63's should be good for that. They flex a ton and add lift depending on how many leaves are in the pack
Old Jan 11, 2014 | 10:00 AM
250000_yota's Avatar
I don't think 63" chevy's are long enough for the t100. Personally, I'm really happy with my Toytec shackles...check out my build. They are originally for a first generation tacoma. They equal out to about 2 inches on my truck, and i think it's under a hundred to do it.
Old Jan 11, 2014 | 07:49 PM
CJM's Avatar
CJM
Shackles or add a leaf. I have an add a leaf from a spring shop on my T100 and I could easily fit 33's. The add a leaf isnt a huge thick overload junk leaf like they sell usually, but a regular leaf that gives about 1.5" of lift and rides better than those thick overload leafs.
Old Jan 13, 2014 | 09:10 AM
Cjm, are you happy with the AAL on your truck? That was my first route to lift the rear of mine, and it rode stiff as a board. I swapped to shackles within 6 months.
Old Jan 13, 2014 | 05:22 PM
CJM's Avatar
CJM
Quite happy actually. About 5 years ago I contacted a spring shop to re-arch my leafs and add a leaf to the pack. The leaf they added is not an overload leaf, but a regular leaf and I gained a good 1-1.5" or so. It added a good bit of payload as well, about 2 years ago I went to the scrap yard with so much stuff that the truck was light on the frontend and I was towing a small trailer as well, I weighed in around 8000lbs, the truck itself comes out to about 4500 at best lol. the bed was sagging and I had to air the tires up to 50psi but she did the 10 mile run.
Course my T100 has bilstein HD shocks and C rated LT tires so it doesnt ride like a caddy.
Old Jan 14, 2014 | 07:56 AM
Ya mine was a procomp I believe. I'm thinking about changing up my set up this coming summer. My brother just redid his lift kit on his Tacoma, so I was going to Change to his Toytec adjustable rear shackles and a Toytec AAL with bilstein's.
Old Jan 14, 2014 | 10:08 AM
CJM's Avatar
CJM
The reason the truck rides like crap if you do the cheapo add a leafs is b/c they are thick arse hard leafs that dont flex it all. The key for me was to use a stock like leaf. If you could find a junkyard with a 99-06 tundra you can yank the springs, they are the same for the reg/x-cab not sure about the dbl cab tho.
Old Jan 14, 2014 | 07:26 PM
Ya I was contemplating that. I have a stock leaf pack from a '86 sitting out back. I was thinking about pulling a leaf from that and adding it in for a little bit more load carrying capability.
Old Jan 14, 2014 | 07:54 PM
Black_1985_SR5's Avatar
I use a floor jack to lift the back of my truck works on the front also
Old Jan 14, 2014 | 09:54 PM
85sr5excab's Avatar
I like ur style.
Old Jan 15, 2014 | 04:26 AM
Yes...very very helpful. You input was very, enlightening.
But I do prefer to use a two post lift. A lot less crawling around on the ground.
Old Jan 15, 2014 | 04:11 PM
Lol its better to be a smartass than a dumbass i guess... i agree on the lift
Old Jan 22, 2014 | 09:25 PM
86bedlesstoy's Avatar
I have a Chevy 63" complete kit everything ready for install. Have not heard many reviews for it installed on the T100. Was originally for my 86 4runner but never got around to it.
Old Jan 22, 2014 | 10:00 PM
cman1's Avatar
zuk mod? i got a pair of 13" blackmagic spring i just took off my pickup.$30.00 plus shipping.
