1990 Toyota 4runner humming noise
Hey guys. Looking for some help. Lately I've been hearing a humming noise from the front end. Usually happens around 40 mph. It seems to be coming from the right side but I can't be positive. Also it seems to be more often in the cold weather. It will last for as little as 1 sec to a few minutes. I was thinking wheel bearings? I do feel a small vibration in the floor too. Any help would be greatly appreciated. Thanks!
I don't know if they have ever been replaced. I've only had the runner for a few months. I'm going to check some things out this weekend. If it is the wheel bearing do i need any special tools to replace them?
Hey I know this goes against all mechanic rules about using the right tool for the right job, but I used a huge adjustable wrench, and/or a big channel lock to replace mine. My bearing is still fine (knock on wood)
Ok, latest update. On my way home from work I dropped the runner into 4WD. The humming noise was suddenly gone and stayed gone even after I put it in 2wd. I probably had in 4 HI for about 5 minutes. Now I'm thinking a CV axle. Whatta you think?
Yeah, I hear what you're saying. The CVs still turn in 2wd though. Man, I don't know, I'm gonna jack it up tomorrow and see what I can find, hear, feel. I just know that when it's hummin it drive me nuts. I'll update the thread when I know more. Thanks for your two cents.
In this link he has a 87 with manual lockouts.. Could be different from the auto locking hubs
http://www.ttora.com/forum/archive/i.../t-110212.html
Ok, latest update. Today I checked the bearing play with the tire on. The was a little bit of play. Maybe about 1/16". So, I took everything apart and looked at the bearings. They were fine, no rust pits or excessive sloppiness. I did notice that the end of the CV shaft had play up and down. It seemed like a lot. Is this normal? Also, I was looking at some other posts and the bronze bushing inside the spindle might be the cause. Anybody else heard of this? The one thing that got my attention was the repeated reports of this problem when it's cold outside. I first noticed my issue on a really cold morning. Anyway, I cleaned everything really good and put it all back together. No more play, took a drive everything seems good but it's not cold out today.
FS[MidWest]: 1995 4Runner 5vz 4x4
vasinvictor
Jan 20, 2016 12:39 PM
JaredL
Jun 16, 2015 04:47 PM
