MPG, Cold air intake and POOGS??
My rig is an 89 4runner with a 22re and auto. Since I have installed my cold air intake I have been experiencing some POOGS (Phantom Out Of Gas Syndrome) sometimes when I accelerate from a stop and occasionally while I cruising along. I know some of y'all don't believe in a cold air system, but I know with the current auto tranny it doesn’t wander through the gears nearly as much and mileage has increased, I don't know how much, but now I'm getting 15MPG with 265/75-16s. My header should be here tomorrow! When I’m done, I will be running a 5spd, 235/85-16s (same height, +/- 32” but less resistance) and may go from my current 4:30 gears to 4:10S to try and get a couple more MPG. Not sure what I can expect to achieve, but 22-23 MPG would be nice.
Is your questions what could cause those symptoms? If so then have you changed your fuel filter yet. It can be a PITA and that's why many people don't do it but that can make a big difference. Also have you run any Seafoam through your truck. I have heard the if you run it through the break booster it doesn't get to the #1 cylinder. But if you by the spray can of it and put it through the intake it gets all 4. Seafoam is like the wonder drug for our trucks.
Tacoma1313
Aug 17, 2015 05:44 PM
