General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
Re wiring steering column with aftermarket kit
Old Dec 16, 2013 | 07:16 PM
Sean Curry's Avatar
So I completly gutted the toyota electrical system, for a chevy v8 swap. I purchased a ez 12 wire harness. I have the schematics for this truck, And I have most wires figured out on the steering column for the lights and turn signals, except for a few. Does anyone have a dummy downed version of which wire goes where, IE which one for headlight power, turn signal flasher/hazzard flasher? Those are the main ones I am not sure of. Its for a 1984 toyota with a SR5 steering column that I am hoping to reuse if its not too much of a issue. I have searched but not really found what I am looking for. I would be happy with a link to find this info, anything helps.
P.S I should start a build thread here soon if anyone is interested in a typical 3 linked front toyota on bead locks with a V8. LOL
Old Dec 16, 2013 | 11:21 PM
wyoming9's Avatar
Red face
You have the Wiring diagram for your truck and are unable to figure out what you need.
This SR5 column is from the same year??
Are you using the stock combination switch or all after market??
Old Dec 17, 2013 | 07:05 AM
Sean Curry's Avatar
Stock switch, I believe the steering column is stock. Yes I have the schematics, I think I am over thinking where to hook the flasher to. When I look at the schematics they show the relays and what not .i have all the output wires for the turn signals and lights figured out, just not 100% where to hook the power wires up to for them. Thanks
smthwsn357
May 1, 2024 07:28 AM
XtraCab
Apr 12, 2020 05:25 AM
jerusry
Oct 19, 2015 05:28 PM
Sep 4, 2015 09:27 AM
Suprarossa
Jul 6, 2015 05:21 AM
