Ac idle-up VSV, stuck?
Old Dec 1, 2013 | 10:42 AM
pinstripe_chuck's Avatar
I have a 90 PU with 22r. When I turn the AC on, the diaphram pulls and increases the idle as it should but when i turn the AC off it does not release the vacuum to decrease idle. I have to actually pull the hose off of the idle up diaphram before it will return to normal idle. How does the VSV release vacuum once it is turned off?
Old Dec 1, 2013 | 11:14 AM
Punchy's Avatar
You can wd40 the VSV, Also make sure the vacuum hoses are correct, If there backwards it can do that.
Pri$erulz
Nov 17, 2019 08:03 PM
Redeth005
Jun 28, 2018 08:16 PM
Boomer8404
Sep 24, 2015 01:12 PM
andrewtexas123
Sep 23, 2015 07:48 PM
