Engine Swaps Swapping an engine in your Toy, here is where to learn how
91 4runner with 5vz-fe swap.
Old Nov 28, 2013 | 08:46 AM
CodyRunner's Avatar
So I have a 91 runner and it has a 98 5vz in it. On the highway I run about 75-80mph at about 3100rpm. Is that normal?
Old Dec 5, 2013 | 07:01 AM
alfio's Avatar
depends on the transmission and rear axle gearing - what are the specs on those?
Old Dec 5, 2013 | 09:49 AM
CodyRunner's Avatar
Factory 4.88 gears and I'm not sure about the tranny.
Old Dec 5, 2013 | 10:07 AM
alfio's Avatar
stick or auto?
Old Dec 5, 2013 | 10:24 AM
92yota92's Avatar
Wether you used a pre or post 95 trans the gear rations shoudl be the same.
5th gear ratio in either a new or old r150 is .83 and that's a little short. The At is closer to a .7 ratio in 4th so if it's standard it doesn't sound too far off it's its an auto it might be a bit high.
Tire size can be a factor.
Old Dec 5, 2013 | 04:22 PM
SacRunner's Avatar
What size tires?
I was somewhere around there with 31's and 4.56, but with the 33's I have now (and the same 4.56's), the engine speed is a little lower.
And just so you know, the engine speed (rpm) for a given wheel speed (mph) has nothing to do with the motor, it's all about the various gear ratios between the transmission, axle, and tire diameter.
snosurfer
3.4 Swaps
Aug 15, 2024 02:11 AM
icentropy
Sep 16, 2020 02:47 PM
coreyedwards7611
Jan 16, 2016 06:38 PM
BeMiceElf
Oct 10, 2015 09:40 PM
