1995 v6 3.0l Engine losing power
Old Nov 13, 2013 | 11:14 AM
sean941's Avatar
Post 1995 v6 3.0l Engine losing power
I just recently put new injectors in my 1995 v6 3.0l engine because it was misfiring and it started running much smoother with the new injectors. After 3 days I was driving and the engine just started to lose power and my truck would shut off. Not sure if maybe my fuel pump is going out or what. I need this truck to run my part time lawn service and without it I am kind of stuck if anyone could help with some advice.
Old Nov 14, 2013 | 08:51 AM
KingsShadow's Avatar
check to make sure you have all the vacuum lines routed properly and no cracks in the air box tubing. What exactly did you do to try to remedy the problem first?
Old Nov 14, 2013 | 08:56 AM
scope103's Avatar
Codes? Do you have spark at each plug? Are the plugs wet?
Diagnosing a problem like this on the internet can take time. If your business is halted as a result, you might consider just taking your truck to someone (a mechanic) who does this for a living.
smthwsn357
May 1, 2024 07:28 AM
Iceman4193
Oct 16, 2015 10:50 AM
LotOMiles
Sep 14, 2015 11:45 PM
Peevedkitten
11
Aug 31, 2015 06:57 PM
defrag4
Jul 31, 2015 10:50 AM
