Should I remove another leaf from the front
Old Oct 15, 2013 | 12:27 PM
n1d0n's Avatar
Should I remove another leaf from the front sas question
Hello,
I have an 1986 toyota pickup that I sassed 1-1/2 ago and I thought that by adding a winch and everything that the shakle angle would be better but the thing is still almost straight.. I have the 3"TG sas kit and I have already removed a leaf in the front..
My question is should I remove another one.
2 reasons why I want to remove a leaf.
1- the truck is high to me... I would love to have the center of gravity lower.
2- I don't think that it will go lower than that..
I have a 1.9 tdi swap in that truck with nozzles and a tune obviously.. and it is a lot lighter than the V6 that was in there.. maybe thats why it doesn't go lower.
would there be any issue in removing another leaf and which one should I remove?
Old Oct 15, 2013 | 02:21 PM
n1d0n's Avatar
anyone??
should I put more information?? more pictures?
Old Oct 16, 2013 | 03:52 PM
Cyberman's Avatar
Did you originally have the HD springs?
Sounds like the front hanger wasn't positioned correctly, if your shackles are straight.
I'm not sure whether it would be wise to remove a leaf or which one.
Old Oct 16, 2013 | 04:08 PM
Teuf's Avatar
Do not remove a leaf,,,,,,, lets see the shackle angle? Maybe the next shortest shackle. You could in some way add weight to the front. Did you expect the SAS to sit lower?
Old Oct 16, 2013 | 06:23 PM
BigBluePile's Avatar
I took two springs out....of course I have 4" TG hd springs.....hmmmm
Old Oct 16, 2013 | 08:04 PM
Teuf's Avatar
Mmmmmmmmmmm
Old Oct 17, 2013 | 02:42 AM
n1d0n's Avatar
Yes it's the 3" hd springs.
My front hanger at the beginning was 3/4 of an inch forward but now it is flush with the frame. I don't have any pictures with me but I could get some tonight.
Old Oct 17, 2013 | 02:24 PM
n1d0n's Avatar
Hey guys here are the pictures.
Sorry for the rust but that's how it is here. :-(
Old Oct 17, 2013 | 03:24 PM
Cyberman's Avatar
Ya, that shackle angle isn't very pretty.
I'll have to look at mine, but I think my hanger is 1/4" back from flush. And I have the same springs.
Old Oct 17, 2013 | 03:32 PM
Teuf's Avatar
MMMM not so good. Whats the gap i see in the solid hanger in the front?
Old Oct 17, 2013 | 03:35 PM
Teuf's Avatar
If anything, you could have the shackle hole in the frame welded up and then recut the hole closer to the spar thats an inch or 2 forward?
Old Oct 17, 2013 | 03:38 PM
Teuf's Avatar
mine was in the middle between the spars.....[IMG][/IMG]
Old Oct 17, 2013 | 03:49 PM
Cyberman's Avatar
Spar?
Old Oct 17, 2013 | 04:14 PM
donomite49's Avatar
Looks like you need 2" longer springs.
Have you looked into a ruf (rear up front) spring swap?
Btw how does that tdi swap work? Mileage?
Old Oct 17, 2013 | 04:37 PM
Cyberman's Avatar
Post a pic up of the rear frame mount. Mine is up close to the front of the body mount bracket (not centered).
Old Oct 19, 2013 | 04:19 AM
n1d0n's Avatar
Here is the picture of the rear mount. Sorry that it
Took a while.
Also sorry that it's not clean. Lol
Old Oct 19, 2013 | 05:17 AM
dropzone's Avatar
Fossilized
What V6 did you have in there before? 3.turd wasn't stock till 88..just curious.
get a hold of a couple of sets of rears springs and build yourself a couple of RUF packs...mix and match till you get what you want..
Old Oct 19, 2013 | 09:14 AM
n1d0n's Avatar
it was an v6 from an 1988 that was done by the previous owner..
88sasturbotoy
Jan 30, 2026 01:57 PM
Sep 4, 2015 09:27 AM
coffey50
Jul 28, 2015 10:55 AM
ItsJustD
Jul 7, 2015 07:49 AM
Nickdigg
Jul 7, 2015 06:04 AM
