Do i HAVE to get manual hubs if i lift?
I tried to do a search and couldnt find a definate answer. Do i have to get the manual hub conversion for my 04 tacoma if i do a 3 inch suspension lift and then do a 1 inch diff drop? what would happen do the ADD's if i didnt change them out?
There are lot of people running that type of setup and most of them seem to get by. It's definitely not an ideal situation and you may encounter problems. It also depends on how much and how hard you wheel your truck. You also might be subject to vibrations at higher speeds since the CV's are angled in such a fashion. You are at the extreme limit of the stock CV boots and they will most likely fail in a much shorter time frame, even if you don't wheel it. MechaTech makes high angle CV boots for our trucks which pretty much eliminate the boot wear problems associated with that much lift.
Hope this helps.
G
Hope this helps.
G
3" in the front is pretty extreme, but a lot of people seem to get away with it. Most, if not all of the manufacturers of lifts systems recommend no higher than 2.5" in the front without Manual Locking Hubs. It really depends on the individual truck, the driving habits and how hard you wheel it. If you aren't going to wheel it, and are just getting the lift for looks, you're probably going to be ok. But you won't really know for sure until you get it all done, aligned and drive it for a while.
I would get the MecaTech boots if my original boots failed. I am sitting right around 1.5" of lift in the front, with a 0.5" Diff Drop and my CV's are totally fine. I am going to add another inch to the front once my SAW's arrive. I'll add another 0.5" to the diff drop and I will see how things look at that point. I'll probably be okay.
Hope this helps.
G
Hope this helps.
G
would i need to do a diff drop if i did just a 2 inch in the front? ive got good clearance now but i just need to get more than an 1/8th of a in gap from my tire to my fender. i am gonna try to use it to its fullest potential.
I have 3" on the front and a 1" diff drop. 3 days after putting the lift on one of my boots ripped. I replaced the axel and within 6 months the boot ripped again. I then put the Mechtech boot on and it has worked fine now for about 7 months. The other boot and CV is the stock one and it's still holding up fine. So it is all a matter of luck, but your lowing your odds the higher you go.
Here is what the CV's look like
Now, I only got 2.75'' in the front but plan on installing those 5mm packers on each side to get closer to 3''. I will then do the diff. drop and that should help keep the CV boots from rubbing together.
Ben, did you do an alignment yet? If not, wait to pass final judgement on how good your CV angles look until you get the alignment done because your CV angles will be a LOT more extreme since the lower arms get pushed out by quite a bit to get the front end back to factory specs. If you've already done it, then ignore what I just said.
However, it looks like you have some positive camber going in that pic, so I'm guessing you haven't done the alignment yet.
My .02
G
My .02
G
My .02
G
My .02
G
I have a 5pm alignment today. I will know then.
Mean04, I hope this info helps. I think we have the same truck, 2.7L standard cab with ADD's. I was thinking I needed manual hubs too but all the reseach I did I found it wasn't necessery to get the lift needed to fit the 33X10.5. After the alignment, 5mm trim packers and the diff drop I should know for sure how the CV angle is going to be.
yea, keep my posted grntaco. we do have about the exact same truck. i love it. what do you think the timeframe will be on the packers and diff drop? my email is supersportbikerider@hotmail.com or just send a private message to me on here. i wanna go with a
Hey Ben,
Thanks for the input. Take some pics and let us know how it turns out! It would be great if you could do post alignment/no diff drop and then post alignment w/ diff drop.
Peace!
G
Peace!
G
Mean04, I will have the alignment done today and I will do the packers and diff drop tomorrow evening. I will e-mail you.
Originally Posted by GRNTACO
I will Doc.
Just throwing this out there, the ORS manual hub kist also gives you alot thicker axle shafts and hardened outter CV's. More to it than just a set of hubs. The entire package is stronger.
