Im new in the toyota world. HELP
Old Oct 12, 2013 | 02:30 PM
bones7977's Avatar
I bought a 1989 Toyota pickup 2wd with the 22r for $750. When I purchased the old girl, she was spitting and sputtering. The previous owner was frustrated with it he had put a new Ignition module, plugs, wire, cap and rotor on it. I drove it 6 miles home. I checked the timing and the distributor was off one tooth, now it she will purr and be in time for 30 seconds and then the timing becomes erratic -10 to +10. any advice would be greatly appreciated. still missing bad except for the 30 seconds of happiness. Thanks all
Old Oct 14, 2013 | 10:33 AM
Gamefreakgc's Avatar
Is this when idleing? If so, check you TPS. It might be out of whack.
Any check engine lights?
Old Oct 14, 2013 | 01:22 PM
Bullet22r's Avatar
It can't be a TPS... it's carbureted. Anyways, have you checked that the cam sprocket is pointing at 12 o'clock when the engine is at tdc?
Old Oct 14, 2013 | 05:15 PM
Sometimes I don't bother reading everything.
Old Nov 5, 2013 | 05:08 AM
bones7977's Avatar
I thought originally it was timing. it still may be. i have not checked the sprocket yet but I took some carb cleaner and sprayed some of the jets and it stabilized a little. it still has no power and still idles rough. I considered rebuilding the carb, but i can see that not ending well.
Old Nov 6, 2013 | 05:27 AM
Bruinpilot's Avatar
I recently bought an 89 as well. I had similar problems. I ended up just desmogging and going with the weber carb. I also had to replace the timing chain and it's related components. Now it runs awesome. Here is a great thread that may help you: https://www.yotatech.com/forums/f114...torial-264405/
Colington
Mar 8, 2020 09:51 AM
Sep 4, 2015 09:27 AM
crashburnoveride
Aug 28, 2015 09:20 PM
nick b
Jul 11, 2015 04:38 AM
