Difficult to turn engine by hand - spark plugs removed
Old Sep 16, 2013 | 05:35 PM
92Pkup's Avatar
1992 Pickup 22re auto
I intended to adjust my valves. Got the valve cover off then went to crank to TDC. It is REALLY difficult to crank by hand. No cheater bar, just the ratchet itself, its possible to turn but meets a lot of resistance. Moves somewhat freely at a point then gets near impossible to turn again. I dont want to force it so stopped. All four spark plugs are removed, its in park. Am I forgetting something?
The truck was running fine prior to doing this but a little rough and underpowered. It had a new block and rebuild 8000 miles ago by previous owner
I notice the belts are really tight, could that do it? I tried adjusting them but the adjuster screw backs out but the pulley does not move. Whats up with that?
Sigh
Old Sep 16, 2013 | 07:46 PM
osv's Avatar
osv
there should be a belt deflection spec for measuring how tight the belts are, check that first.
which direction are you turning the engine? the same direction that it runs?
Old Sep 16, 2013 | 07:50 PM
92Pkup's Avatar
Turning clockwise, yes
Old Sep 16, 2013 | 08:10 PM
osv's Avatar
osv
did you pull the distributor during this period? or loosen/tighten anything other than the belt? such a bizarre problem...
I don't have any 22re auto trans experience, but i'd be hard pressed to see how it could cause this.
Old Sep 16, 2013 | 08:11 PM
combatcarl's Avatar
On the belts that use a bolt to set tension, you need to loosen the pulley bolt by half a turn or so, then when loosening the tension bolt, it will slide out of tension. Make sense? It's the bolt in the center of the pulley.
Sent from my NSA screened iPhone using YotaTech
Old Sep 16, 2013 | 08:16 PM
92Pkup's Avatar
Did not pull the distributor. Just pulled the valve cover and plugs.
Thank you for the pulley explanation; makes a lot of sense now.
Tomorrow I'm going to pull all the belts off and see if that makes any difference
Old Sep 16, 2013 | 09:35 PM
combatcarl's Avatar
It is kinda weird, now that I think about it. I can roll mine over with a 1/2 ratchet, slowly, with plugs in. Just have to let the pressure drop before rolling over TDC on the compressing cylinder(s). Is it not supposed to be that way? I never bother pulling plugs, unless I'm checking them or replacing them.
Old Sep 17, 2013 | 10:35 AM
92Pkup's Avatar
Well I loosened the belts and that made it a little easier to turn but still difficult (all the pulley bearings spun fine). I pushed harder and got it to turn to TDC and did the valves. One was way off but the rest were good.
Maybe its harder to turn than Im used to because of the new piston rings? Maybe the shop installed the wrong size something? Seems like if theres that much resistance its robbing power
Old Sep 17, 2013 | 11:21 AM
Gamefreakgc's Avatar
Or it could mean you now have awesome compression now, making it hard to compress the air by hand!
Old Sep 17, 2013 | 02:28 PM
92Pkup's Avatar
No compression, plugs were pulled
Old Sep 17, 2013 | 09:30 PM
Kiroshu's Avatar
Sounds like piston to cyldiner wall clearance too tight.
Not a good thing but if the engine has run 8,000 miles like this then you may be ok.
>_<
Sometimes if piston to cyldiner wall clearance is too tight when the engine warms up it will actually seize.
But obviously there is a resistance factor somewhere in the engine.
voiddweller
19
May 2, 2016 09:10 PM
marcusSRG
Jun 27, 2015 07:13 AM
torgeir
Jun 25, 2015 05:26 AM
saphirekosmos
Jun 22, 2015 10:26 AM
HBoss
7
May 26, 2005 04:48 PM
