Oil leak turned out to be much more
I don't post often but I figured I would share. 94 p/u 4x4 22re manual
Moved up to ak pulled the truck in the garage to winterize it. Figured while I had it apart I would go ahead and fix my pesky oil pan leak. After removing the pan I found this waiting for me
Initial thought is timing chain tensioner. But who knows?! If anyone has any advice please feel free to share it with me
Thanks
-Jake
Thanks
-Jake
you could remove the timing cover without removing the head, since you've already remove the oil pan that's already half the job. It seems like you already have steel backed guides, thats kinda odd for it to break. Makes me wonder if my china made guides will break......
Idk what it could be, it could be any left over broken pieces from the previous guides. Engnbldr sells quality timing chain kits, "The H/D timing kit is $58.80. The kit with cover is $88.80.
The 4 piece combo, timing kit, cover, coolant pump and oil pump is $154.80."-Ted
your cover looks good - no grooves from the broken guide/chain slapping on cover issue. Though I don't see a drivers side guide there? maybe I forgot what it looks like?
ENGNBLDR is the way to go IMHO, for the Front End Kit or FEK (call them up or search eBay for ENGNBLDR. I got my timing kit and head from them and tons of guys here swear by them.
My guess is what you found it old wreckage. Doesn't hurt to get a new timing kit and re seal the front end with new parts - it's cheap insurance.
