Pre 84 Trucks 1st gen pickups
trailor lights
Old Jul 2, 2013 | 06:28 PM
catfish21's Avatar
trailor lights
Hello guys I just purchased me a boat and my ol yota doesnt have trailer wiring, I did a lil searching and found out how to identify the wires by turning the turn signal and everything one by one and test for continuity but has anyone did this other ways or used certain kits just looking for a little help to try and do the.best job possible thanks
Old Jul 2, 2013 | 08:32 PM
aztoyman's Avatar
Toyota has amber turn signals instead of a dual element turn signal /brake light like many domestic vehicles so you need a trailer wiring kit with a converter box.
You can get them from U-Haul or even Wal-Mart. You can get plug in kits that you don't even have to splice (for some vehicles) or universal kits that you do have to cut and splice.
Pretty easy, just follow the instructions.
Old Jul 3, 2013 | 01:12 AM
catfish21's Avatar
Yeah I was in AutoZone last night and seen they had some kits that required no splicing but it was for Toyota years 84-95 well I have a 82 so not much help there but I'll look some other places, but I would much better have something that plugged in instead of splicing everything
Old Jul 3, 2013 | 03:59 AM
catfish21's Avatar
What is this converter your talking about the only kits I seen was the ones that had the plug and the wires to make the splices, that wouldn't work
Old Jul 3, 2013 | 06:18 AM
Bingle's Avatar
Sorry buddy, but with first gens, you're S.O.L. You're going to have to get a cut and splice style converter box, or universal. I did the search years ago and just had to splice one in. I used the instructions with the kit and my trusty haynes manual (FSM would be way better, but I used what I had at the time) with the wiring diagram in the back and made it happen. Not that hard.
Old Jul 3, 2013 | 06:23 AM
catfish21's Avatar
Ok it doesn't seem that hard but the kit I looked at at AutoZone just had the plug and a bunch of wire with it to splice into my wiring will that work I really don't know what this converter is Yall talking about I thought just splicing into the wires would work and thanks for the help cause I'm picking the boat up Friday and need my lights to get it home
Old Jul 3, 2013 | 06:48 AM
Bingle's Avatar
trailers take a combined brake and turn signal input (like domestic trucks, brake lamp flashes for turn signal) and toyota has seperate wires/lamps for those two functions so you need a box that combines the two signals into one.
something along these lines:
http://www.ebay.com/itm/Curt-Wiring-59146-Universal-Taillight-Converter-/140967120212?pt=Motors_Car_Truck_Parts_Accessories&hash=item20d24b8d54&vxp=mtr
Old Jul 3, 2013 | 07:16 AM
catfish21's Avatar
Do you know if that kit that you showed me will work I'm sorry to keep bugging you .
Old Jul 3, 2013 | 11:12 AM
Bingle's Avatar
Probably, but not sure is it's right. I went to a RV/camper sales and service place near me when I got mine. Asked a service guy what I needed and he handed it to me.
Old Jul 3, 2013 | 12:13 PM
83Toyota88's Avatar
This is what I put on my 83. You will have to splice into the wires. I did it inside in the area behind the tail light where the the wire harness plugs into the tail light.
http://www.autozone.com/autozone/par...h&newYmme=true
Old Jul 3, 2013 | 03:20 PM
wyoming9's Avatar
Red face
I for the most always put more lights on the trailer .
Then I have a separate turn signals.
then I just use a regular 7 conductor plug on all my vehicles.
Those little flat 4 pin plugs are a pain along with those converters.
Old Jul 3, 2013 | 03:45 PM
catfish21's Avatar
Well I'm bought to get off subject a lil here what do you guys think about pulling that boat with the ol 22r it's a 17' bass tracker aluminum and it weighs loaded down about 1800 pounds, I think I'll be ok except for big hills and sudden stops what do Yall think are what have Yall towed with your first gens with 22r
Old Jul 3, 2013 | 03:46 PM
dropzone's Avatar
Fossilized
^^a 7 pin connector would be overkill on a first gen. They barely have enough guts to pull themselves let alone a load that would require brakes.
OP- google 4 pin connectors. It is not that hard to wire the adapter in.
Solder your connection, don't use those blade style crimp splicer things..you will have problems.
Don't expect to pull more than 1500lbs.
Old Jul 3, 2013 | 03:57 PM
catfish21's Avatar
Ouch that is making me nervous now there is no turning back now I've already purchased the boat I sure as Hell hope I can pull that boat. I surely thought I would be ok pullin it
Old Jul 3, 2013 | 04:16 PM
Toyota~Boy's Avatar
I have both a 87 and 93 and have pulled well over 2 ton quiet often with out problems.
Both trucks are 22R and RE
Brakes are hooked up 50/50 ( no LSPV )
33" tires on both
4.88 gears on both
I can run 70 MPH pulling a 16' car trailor loaded with another toyota pickup that's up most his as well. Stoping is no problem.
Here's a example:
Hope this encourages you.
By the way the Convertor is a must. Just start cutting a splicing. On the 2nd and 3rd gens the white wire is negative so make sure you have it correct and test each wire prior to splicing or soldering.
Old Jul 3, 2013 | 04:19 PM
catfish21's Avatar
Hey buddy that makes me feel a lil better now looking at that but I'm still nervous but I think I'll be ok thanks man
Old Jul 3, 2013 | 05:29 PM
dropzone's Avatar
Fossilized
33" tires on both
4.88 gears on both
Here's a example:
glad you live on the opposite side of the country.
I pray you have a good brake controller and both axles are braking axles.
That load is too heavy for a toy mini truck
Old Jul 3, 2013 | 05:50 PM
catfish21's Avatar
Well let god be in my hands then I have the v6 upgraded brakes and I do realize it's not going to brake the best in the world but I'm committed now
Old Jul 3, 2013 | 06:47 PM
Toyota~Boy's Avatar
No that trailer does not have electric brakes. My stock trailer does. It's Goose neck tho. I grew up on a farm all my life. My grandpa bout his first toyota in 89. Brand new. Took it straight to garage and had a goose neck hitch installed in the bed. He pulled a 16' & 20' stock trailer to and from every live stock from here in WV all the way to Maine. He kept that very truck up until 2008 when he traded it in on a 08 Dodge Ram 2500. My entire family is sworn by these little Mini Trucks. I pull my trailer everywhere. As I stated above, I stop and go with ease. Just Monday I had 2,100 pound on my trailer. I know because I hauled scrap to the scrap yard. I have know clue what my trailer weighs but I pulled it loaded about 30 miles one way. I live in the Appalachain mountains I'm surround by hilly terrain and with my current gears and setup I have no problem.
Some people may disagree but I for one must not. I'm a experienced driver and fabricator so I trust my truck and my workmanship that's been out into to accomplish my goals.
One thing I did forget to mention. I reinforced my very rear section of frame to handle the extra load capacity I throw on it. I believe that's a must do thing for those that pull a trailer.
Anyways back to OP. good luck buddy. Your truck should handle that boat with ease considering its in good running condition.if your running a larger tire then 31's and still have 4.10's don't plan on running highway speeds. Keep your brakes in good condition and watch your temp gauge to make sure your not over doing your engine when in lower gears. If you need help figuring out your wiring let me know. There's a thread on here that I gave another member directions on hooking up lights on his flat bed. If may or may not be helpful to you since your a 1st gen however that wiring the same between 2nd and 3rd gens. I will try to find you a link here shortly.
Old Jul 3, 2013 | 06:56 PM
Toyota~Boy's Avatar
https://www.yotatech.com/forums/f131...wiring-265363/
