where to put airbag wires on new a arms
Old Feb 17, 2004 | 07:32 PM
bobzemuda's Avatar
When i was fitting my Inland A-Arm last night, I zip tied the airbag wires to the arm as I obviously couldn't reattach the bracket to the arm.
Is this safe, or should I take the wires off the bracket and zip tie them on? Or even still, is there a better solution then this?
Bill
Old Feb 17, 2004 | 07:42 PM
RobT2k's Avatar
What "airbag wire"? The only thing I had that came off the other stock arm was a cable I assumed had something to do with ABS (wheel speed sensor?) The airbag sensor on the drivers side is the only one I had to move temporarily,but it's under the battery tray.
Old Feb 17, 2004 | 07:45 PM
bobzemuda's Avatar
I get it, I mistook that for the airbag wire, I was reading steves directions and it was late, and I was tired. As you can see, I'm only partially handy. I insisted on taking care of all this myself, however, as I wanted to know how it all worked in case of problems down the road. It's definitly helped my confidence working on my car.
So I guess it's the ABS wire I'm looking at, but I'm still wondering what the safest thing to do with it is.
Bill
Old Feb 17, 2004 | 09:37 PM
RobT2k's Avatar
I just left mine how it is, it allows the arm to cycle through it's full range of motion. Several offroad trips later, still no problems. I thought about tying it back, but everything I thought of seemed to hinder it's range of motion.
Old Feb 18, 2004 | 02:17 AM
Bighead's Avatar
I kept the ABS wires attached to the bracket and zip-tied the bracket to the upper control arm. Even though Steve's picture doesn't clearly show it, that is how it is attached on his.
bigjstang
Jun 2, 2025 03:56 PM
icentropy
Sep 16, 2020 02:47 PM
toyota32
Jul 6, 2015 05:42 PM
ptb12
Jul 5, 2015 01:49 PM
