1995 4Runner SR5 V6 4WD transmission Speed Sensor Location
Old May 18, 2013 | 06:23 PM
zonian73's Avatar
Does anyone have a picture of the transmission speed sensor location?
Old May 19, 2013 | 05:26 AM
scope103's Avatar
As usual, to get the right answer, you must first ask the right question.
There are two speed sensors, eponymously VSS1 and VSS2. VSS2 measures the speed of the transmission, for shift points and the like. But that doesn't give you the speed over the ground, because you have a 2-speed transfer case. So VSS1 is after the transfer case, and is used for the speedometer and cruise control.
Perhaps this will help.
Old May 19, 2013 | 05:59 AM
zonian73's Avatar
Thank you. The problem I'm having is once my truck starts warming up is not down shifting into 1st and 2nd gear and my O/D light starts flashing on my instrument cluster. After doing some research, I've found that it could be the transmission speed sensor or the solenoids. I'm going its just the speed sensor because I believe my solenoids are inside the transmission itself.
Old May 19, 2013 | 07:02 AM
scope103's Avatar
O/D Flashing. Hmmm. I'll bet your transmission is trying to tell you something. But what? http://personal.utulsa.edu/~nathan-b...31diagnosi.pdf
(What kind of "research" DID you do?)
Old Jul 16, 2013 | 02:00 PM
colbyman's Avatar
what does the speed sensor in the transfer case do? if it was bad would it prevent me from going into 4 low? even though the linkage will go into 4 low
Old Jul 21, 2013 | 02:50 AM
zonian73's Avatar
Turned out to be an electrical problem. Some wire by the oil filter. I also drained and replaced the differential fluid in the front and rear.
mussy01
Dec 13, 2016 08:20 PM
shrek99352
Aug 31, 2015 04:16 AM
mund1011
Aug 16, 2015 07:10 AM
ty1er
Aug 1, 2015 11:53 PM
