1988 toyota 22re won't start/ no spark
Old Apr 12, 2013 | 12:10 PM
brandoonie's Avatar
I have a 1988 toyota pickup that i recently put a new head on and now it won't start. I checked for spark and it has no spark. When i had the engine aprt, i ran the distributor through a parts washer and i was wondering if that could've messed up the pickup coil. It also makes a loud noise from the igniter, like a knocking noise. I've verified that everything is hooked up right so i don't know what the problem could be. I also ran the codes and there was none. Any information regarding this issue would be greatly appreciated.
Old Apr 12, 2013 | 12:23 PM
scope103's Avatar
Originally Posted by brandoonie
..., i ran the distributor through a parts washer and i was wondering if that could've messed up the pickup coil. It also makes a loud noise from the igniter, like a knocking noise. ...
I'm pretty sure you should keep anything electronic or even electrical out of a parts washer (are you talking paint thinner only, or a water mix?) The igniter is strictly an electronics box; any sound at all coming from the igniter would be bad. Are you sure that's where it's coming from? You can use a cheap HF stethoscope, or even the tube from inside a roll of paper towels works well.
Old Apr 12, 2013 | 12:35 PM
brandoonie's Avatar
Well, i wasn't even thinking when i put the distributor in the washer and it was just water. And the igniter is mounted to the coil so it's either the igniter or the coil making the noise.
Old Apr 17, 2013 | 07:58 AM
Osh Ooh Ahh's Avatar
I have an 88 pickup that I can't get to start either... but I didn't put my dizzy in a parts washer.... but I don't seems to be getting any spark.... tailpipe smells of fresh gas though.... firing order is 1-3-4-2 right? and there's no egr on my engine...any adjustments I can make to compensate for that? Just rebuilt the engine..... is it possible that the timing chain is off even though the dots line up and the valves close on number 1 when I'm at tdc?
NEED an expert!
zd92655
Mar 6, 2022 12:58 PM
Sandman
Jul 23, 2015 08:15 PM
puffin04
Jul 10, 2015 09:17 PM
Peteyg39@hotmail.com
Jun 26, 2015 08:15 AM
newzingo
Jun 24, 2015 01:50 PM
