Where does this wire go?!?
Old Mar 28, 2013 | 08:48 AM
Rerunn's Avatar
I recently did a head gasket timing chain whole nine build on my 89 22re pickup. Got home yesterday and decided to run the harness I had to pull from the trans to the head that runs inside the lower intake. Got everything hooked up but ONE ring terminal. I cannot for the life of me figure where this thing goes!!! Its good sized with three red wires going into it. Not sure if its a ground or not but I wouldn't think so with the wires being red but I could be wrong.
Any ideas?!?!
Old Mar 28, 2013 | 09:04 AM
DeadPhish's Avatar
do you have a picture?
Old Mar 28, 2013 | 09:38 AM
Rerunn's Avatar
Not at the moment i meant to taker one the other night but it slipped my mind
Old Mar 28, 2013 | 01:20 PM
Co_94_PU's Avatar
22re ground wire locations - the guide!!!
Going to assume it's faded or maybe like me you might be color blind. Are you sure those aren't/weren't brown?
Brown are grounds, for the computer. Ring terminals are grounds almost exclusively unless it's not stock wiring.
Old Mar 28, 2013 | 01:27 PM
RAD4Runner's Avatar
A problem well-stated is a problem half-solved.
Old Mar 28, 2013 | 01:32 PM
atthegates78's Avatar
It should be the ground that is located on the intake. If yours is like mine there are three bolts on each side of the upper to lower intake. (2bolts,1 nut) The ground should be between the bolt and the intake. its sort of below injector #2
Old Mar 28, 2013 | 01:54 PM
Rerunn's Avatar
I thought it grounded in the intake judging by the way the wire is laying and the length
80Truck
Oct 12, 2025 07:25 PM
sanctfy
All Other Toyota Swaps
Sep 15, 2015 02:52 PM
ToyoToler
Aug 8, 2015 08:43 AM
Daneums
Jul 28, 2015 11:57 AM
TDonkey
Jul 26, 2015 10:14 AM
