2000 4Runner acts like its not getting gas
I bought my 4runner used over a year ago, excellent maintenance history. Its ran great this whole time up until a month ago when a dome light was left on and drained the battery. since then, the truck will not 'get up and go'. it starts up fine, idles fine, but when you try to give it gas it bogs down and won't go. also i occasionally hear something like a backfire coming from the front right of the vehicle. if I'm going down hill i can get it to the 3rd and 4th gear, then it can somewhat keep up. but up going uphill i almost need someone pushing.
I have already replaced the fuel filter, AND the fuel pump... these two did not make the siltiest difference.
PLEASE someone tell me they know what the heck is going on here!!
Good on the maintenance history......but, what diagnostics have been done related to this issue?
When was the timing belt last changed? How many miles ago?
CEL (check engine light) on?
Dirty air cleaner?
Vacuum hose leak?
Bad spark plugs or wires?
How does the oil look?
How does the coolant look?
Dirty air cleaner?
Vacuum hose leak?
Post is far too vague to be able to pinpoint the issue. Could be any number of things. Right off the bat, sounds like TPS or MAF to me.
Also, that backfire sound is the engine backfiring through the intake. You're getting lots of air and spark, but not fuel when you hit the gas. This leads me to believe TPS more than anything else, but again it could be a number of things.
Avenged
Jul 9, 2015 07:55 AM
Jnkml
Jul 6, 2015 01:20 PM
