Runs, but wont start???
Hey Guys,
My 82 wont start by key, but runs fine if you pop the clutch. New starter, new plugs, newer wires, and I cleaned the distributor. It turns over quickly enough that it should start, but doesnt fire. What is the next thing I should check?
Thanks
Thanks
Yes it is very odd. I am stumped.
I have used carb cleaner a few times, and it hasn't made a difference - not even a half spark.
The ground is a good thought; would that change matters for the popping the clutch start? Where is the ground on an oem truck? Mine is just ground out about 10-12 inches from the neg terminal on the battery and its just a bolt screwed into the side of the engine bay sheet metal.
Im not sure about my timing, but adjusting it didn't change anything.
Team420
Jan 12, 2021 04:57 PM
