Length of Dipstick on 2000 4runner
Old Mar 10, 2013 | 08:39 AM
Ipaman's Avatar
I needed a new transmission dipstick for my 2000 limited 4x4 4runner so I ran to Pull A Part this morning. I grabbed one off a 1997 with the same engine. 3.4 v6. It fits fine with a little twisting , but after checking my fluid it is saying its low. I used the correct procedure (Car running shift slowly through gears and check while running.)
Now I am wondering if the dipstick is shorter for the 97. Could someone with a 2000 measure their's quick and let me know what it is?
Thanks
Old Mar 10, 2013 | 09:19 AM
rworegon's Avatar
Tranny dipstick?
Old Mar 10, 2013 | 09:24 AM
Ipaman's Avatar
Yes sir.
Edit: I just checked the parts diagrams for both models from the site in your sig and they are the same part number so that is good.
Old Mar 10, 2013 | 09:29 AM
rworegon's Avatar
What transmission? Look on the driver door column for the code likely A340E of A340F.
Old Mar 10, 2013 | 09:30 AM
Ipaman's Avatar
A340f and its a 4x4
Old Mar 10, 2013 | 01:11 PM
Ipaman's Avatar
Anyone? I could also use the measurement from the base of the dipstick to the highest HOT Mark.
Old Mar 10, 2013 | 03:09 PM
hoghead420's Avatar
I have a 98 a340f and from the bottom of the dipstick to the top notch is 9 inches. ( cough, that's what she said) Don't know if the year difference matters. Thought it might help.
Old Mar 10, 2013 | 03:24 PM
Ipaman's Avatar
Dang 9"!! Mine is only 5 1/2 to the top notch. I feel like less of a man. I never saw my original so i dont know what it was.
Old Mar 10, 2013 | 03:26 PM
hoghead420's Avatar
Let me check again, ill take a picture. I might of looked at the wrong notch
Old Mar 10, 2013 | 03:40 PM
hoghead420's Avatar
Double checked , I have 2 marks on the cool notches about 4 and 5 inches from the bottom, the the hot notches are at 8 and 9 inches . My dipstick top is orange if that helps ya at all
Old Mar 10, 2013 | 03:45 PM
Ipaman's Avatar
Weird. I wonder why they are different? I hope my fluid level is correct. I ended up adding some to make it right according to my dipstick. Although if i had yours i would have had to add more to get to the marks.
Old Mar 10, 2013 | 03:54 PM
hoghead420's Avatar
That is weird, I took a few picts of mine , I didn't take picts on the cold down low. But there about 5 inches, I have 4 notches total on my dipstick. http://i223.photobucket.com/albums/d...310_190312.jpg
Old Mar 10, 2013 | 04:51 PM
rworegon's Avatar
OP, are you sure the dipstick from the '97 and the 2000 A340F are the same part number? I glanced quickly and they look like different part numbers....I may be wrong though.
Old Mar 10, 2013 | 04:55 PM
Ipaman's Avatar
No im not sure. I might just have to get a new one so i make sure i get it right. I ended up adding fluid and its driving fine, but i would hate to cause damage because of overfilling it.
Old Mar 10, 2013 | 05:21 PM
rworegon's Avatar
Getting a new one from the dealer specific to your year, transmission, and model is the safest bet for sure.
Old Mar 10, 2013 | 05:25 PM
Ipaman's Avatar
Yeah thats what I will have to do. Looking at the parts online it looks like there are 4 different dpstick part numbers:
103-34070
103-34060
103-35290
103-35350
Old Mar 10, 2013 | 05:52 PM
rworegon's Avatar
103-34070
103-34060
103-35290
103-35350
Each of those part #'s need to be prefaced with 35 per the PNC and diagram, i.e.:
35103-34070
35103-34060
35103-35290
35103-35350
Old Mar 10, 2013 | 08:29 PM
KZN185W's Avatar
for VZN185L Limited:
For California-spec, it's 35103-34060
for 1997/1998/2000, it's 35103-35350
Old Mar 11, 2013 | 03:02 AM
Ipaman's Avatar
Thank you sir. I am going to head to the dealer today and hopefully pick one of those up. Although i am sure they will have to order it.
Old Mar 11, 2013 | 05:57 AM
hoghead420's Avatar
Wow, never imagined there was so many different dipsticks for the 3.4 from 98-02 . Note to self, be very gentle when checking the tranny fluid. Good to know , thanks.
