1995 tacoma 4x4 2.7 cel on not communicating w/scanner
Old Feb 23, 2013 | 06:35 AM
tackman331's Avatar
I have a tacoma with a check engine light on, I plug the genisys scan tool and it dont communicate with it. Is there a common problem to check for that causes it?
Old Feb 23, 2013 | 06:47 AM
rworegon's Avatar
Try another scanner. My 95.5 with the 3.4 communicates with scanners ok. Are all the pins in the plug straight and wires tight?
Search Habanero's build thread as she had a problem communicating to the state scanner on her 96 w/ 3.4, I believe.
Old Feb 23, 2013 | 07:34 AM
TheDurk's Avatar
Not sure about 99.5, but the 96+ OBDII trucks have a 7.5A "OBD" fuse in the engine room fusebox you should check (if you have it).
Old Feb 23, 2013 | 12:01 PM
tackman331's Avatar
I figured it out, I was putting 95 as the year in the scan tool it wouldn't work. I changed it to 96 and it worked, the truck is really a 95.5.
smthwsn357
May 1, 2024 07:28 AM
mskalmus
May 28, 2017 07:51 AM
raptor510
Feb 17, 2017 07:11 AM
Sandman
Jul 14, 2015 12:36 PM
Seattle_Sign_Guy
Jul 12, 2015 12:38 PM
