Vibration @ 65 mph w/ driveshaft taken “OFF"
Vibration coming on at 65 mph with the drive shaft “OFF”.. When drive shaft is “ON”, vibrations is at 25-40 and 60-70 mph..
Issue occured after a lift with TG 5”. First install was done incorrectly and I busted the CV double cardan joint. I had a shop balance and install a new shaft and check the U-Joints.. After the new rebuilt shaft the vibration was reduce by 80%. I took off the rear drive shaft and put that in gear all the way to 65mph where I felt a slight vibe. There it was pretty consistent. I need to know what can cause that vibration??
86 T4R SAS / Duals
My current measurements:
39” long Driveline / dual cases
TC = 5*
Shaft = 18*
Pinion = 17*
86 T4R SAS / Duals
TC = 5*
Shaft = 18*
Pinion = 17*
First have all the tires re-balanced.
Then shake the shaft to see if its loose at the T-case or pumpkin.
Mine wound up being the tail shaft bearing in the T-case and pinion bearings in the pumpkin.
checked!! and checked!! vibrations seems to occur when i accelerate or steady on gas at that speed. Right with I let foot off gas. its smooth and quite.
trailgoat
Aug 13, 2015 05:54 PM
Tonetrk
Aug 6, 2015 10:06 AM
