1988 toyota pickup 22re 2wd solid axle swap
right now my truck is sitting on a 1991 3L htp 4x4 rear axle. i am going to do one of 2 things for this swap, either keep that rear axle on and put a 1985 4runner sfa if the gear ratio's match up. or, put put a landcruiser front and back axles.
that brings me to my first question.: what is the gear ratio of a 1991 3L htp 4x4 rear axle compared to a 1985 4runner front axle?
and my second question: can i do the sas with a landcruiser axle? if so what year does it have to be? and will the rear axle fit?
the gears ratios should both be 4:10s
but i would definetly go with the truck axles
i kno the old land cruisers (80s) the rear end acctually has a offset pumpkin to the passenger side like the front does you would have to run the divorced transfer case out of the land cruiser also
im thinkin about buying a 2wd (4 the low price) because i blew up my 83 and do the same basic swap to but no ones replying to my thread
6th Gear
19
Dec 10, 2019 07:31 AM
Peteyg39@hotmail.com
Jun 26, 2015 08:15 AM
