Icon upper control arms
Old Jan 24, 2013 | 03:19 AM
ARB1977's Avatar
Are these hard to install? Nothing needs to be pressed in the spindle? I'm debating on getting these vs other brands?
Old Jan 24, 2013 | 11:44 AM
turbo8's Avatar
They are not too hard to install, you will have to press out the upper ball joint from the spindle and press in the adapter slug into the spindle.
you will have to move some stuff around the engine bay to get the upper arm bolts out.
Old Jan 24, 2013 | 12:55 PM
ARB1977's Avatar
Thanks. Are there any tricks other than a press to remove and install the slug?
Old Jan 25, 2013 | 11:46 AM
turbo8's Avatar
I used a modified pitman arm puller to press out the ball joint and to press in the slug.
Old Jan 25, 2013 | 12:44 PM
ARB1977's Avatar
How did you modify the pitman arm puller to work?
Old Jan 25, 2013 | 02:51 PM
turbo8's Avatar
ground it down some, bought it from autozone.
Old Jan 25, 2013 | 03:51 PM
ARB1977's Avatar
Thanks.
justdifferentials
Just Differentials
Jun 13, 2022 07:40 PM
aowRS
Sep 13, 2017 08:22 AM
pickle6415
Dec 25, 2015 07:34 PM
potatopants
Sep 15, 2015 06:26 AM
justdifferentials
Sep 5, 2015 06:52 PM
